Baler pickup clutch problem
   / Baler pickup clutch problem #1
pvcman1
bridge lake bc
mccormack international434
Hi, Have a international 46 baler with pick up clutch problem,pickup wont turn hub just spins so i think it needs new linings at the momment carnt get hub off probably rusted on, wonderd if i could drill a hole through hub and cog and use a shear bolt instead of new linings?
   / Baler pickup clutch problem #2
Absolutely. I can't ever remember getting a hay clump so large (and wet), that a clutch mechanism needed to be involved. Try not to pick up a previously formed bale and you should be fine. You need a 100+ hp tractor and a JD 336 or 348 baler to do that, in my experience.
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
7022 (A50322)
7022 (A50322)
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2015 DODGE RAM...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
