ballast
   / ballast #1
Ledgemere Farm
Veteran Member
Limerick, Maine
A bunch
Is it better to add liquid ballast or cast iron weights to your rear wheels? I have heard some horror stories about liquid ballast leaking and rotting out the rims, but many people use it. I put cast iron weights on my Cub Cadet but had a heck of a time finding ones that fit. Which is better?
   / ballast #2
Either will wprk well and both have their good and bad points.
The cast iron wheel weights are easier to install yourself and can be removed more easily if the need arises. On the bad side they are much more expensive.
The liquid filled tires are cheaper. The liquid has to be installed by someone who knows what they are doing and has the proper equipment.
The weight of the liquid in the tires can be adjusted by the amount of calcium chloride disolved in the water. If calcium chloride is used as ballast tubes must be used unless you are soon going to be selling your tractor to someone you wish to punish.
The calcium chloride will kill vegitation if it leaks out.
Bill
   / ballast
Thanks. The extra money the weights cost me was well worth it to me. Kinda heavy putting them on though!
   / ballast #4
The other reason people use liquid ballast is that it does not add to the rolling "inertia" of the tires, and is alot easier on the drivetrain than a comparable amount of wheel weight.
   / ballast #5
Why not build your own wheel weights? It isn't hard and is a lot cheaper. I among others have built their own using lifting weight plates. I think that the last discussion on this was in the NH Owning/operating forum last week. Look for ' 101 lbs wheel weights '
   / ballast #6
My local dealer has been using antifreeze solution in the tubless tires. No rusting problem with that.
   / ballast #7
There's another forum that addressed this same subject. One of the illustrious posters there suggested checking the local NAPA dealer for the tool to attach to the valve stem. It has a hose fiiting on it as well as an air bleed. I promptly took that suggestion and purchased one for around 20 bucks. Haven't used it yet. I did have chloride put in the rears some years ago. When a puncture resulted in the chloride draining down the drive and killing the first 4" to 6" of sod along the edge, I decided to go the route of somthing more environmental. I plan on using RV pink antifreeze. Not as heavy, but it'll serve my purpose. I also plan on filling the fronts as well. I find I lose some traction at times while turning.
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
Van Trailer (A53117)
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2014 Ford F-550 Altec AT37G 37FT Bucket Truck (A51692)
2014 Ford F-550...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
