Battery maintenance
   / Battery maintenance #1
jem041279
Bronze Member
Abbeville, La
2011 Kubota L3940 4x4 w/ FEL & John Deere 750
LSU, LSU, LSU..... Sry could not resist as I just finished watching the game, now on to business, I am thinking of installing a 2 amp charger on my L 3940. I plan on bolting it in place somehow so I can just plug it in when I feel I need to. My question is due to my job working offshore, I may be gone for a week or two at a time and was wondering would it be ok to leave it charging for that long?
   / Battery maintenance #2
Get you a trickle charger. They are more like 1/2 to 1 amp and some will kick on and off. 2 amps is kind of big running 24/7.
   / Battery maintenance #4
I've got the tender jr and regular tender and the save a battery chargers...
They all work well and I highly recommend any of them.
The marine versions cost a little more and are better protected from the elements and impact as it was told to me.
   / Battery maintenance #5
I kept a battery tender on my Harley for years.
   / Battery maintenance #7
Depends. A float charger is good indefinitely, but a trickle charger will overcharge a battery eventually. Buy a Deltran Battery Tender - they're good for just about any situation. If you only need a charger for storage maintenance, then just get a float charger from Harbor Freight for $6. I have a half-dozen batteries (including my tractor) plugged in pretty much full time using the cheapo HF float chargers.
JayC
Thanks for reply fellows I will look for a float charger
   / Battery maintenance #9
Do not forget your 20 percent off coupon at HF. I have not looked at the tools that work list and wonder if this charger is on it.
   / Battery maintenance #10
if tractor is going to set a long time. i would advise pulling it from tractor, and setting it a piece of wood up on a shelf. as long as not on floor. and putting automatic charger that turns on/off on its own.
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
TOOLBOX W/TOOLS (A53843)
TOOLBOX W/TOOLS...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2018 DODGE RAM 1500 (A53843)
2018 DODGE RAM...
Informational Lot - Shipping (A53473)
Informational Lot...
