Battery Replacement
   / Battery Replacement #1
dmccue
Bronze Member
Melbourne, Florida
Kioti CK20, Yanmar YM2000, and Sears Garden Tractor 19.5HP
Looking for an after market battery replacement for my YM2000 tractor. What about the Treveller line at TSC?
   / Battery Replacement #2
Unless you want to spring for $130-$140 for an Optima "red", I would just get the biggest "sealed" automotive battery I could find. A $80-$90, 800-850cca Delco is good.
   / Battery Replacement #3
Just be sure to get the terminals on the correct side. If you don't, you will have to get new cables. The Yanmar has terminals different than the common US batteries. They are available, but not the same as most on the shelf batteries.
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
