bcs 201 tiller tines running backwards
   / bcs 201 tiller tines running backwards #1
rl3fan
Lafayette,IN
john deere 425
i just bought a 201 tiller when you engage the tines the are rotating the wrong direction it makes the tiller launch forward instead of actually digging. Was wondering what the problem could be any help would be greatly appreciated.
   / bcs 201 tiller tines running backwards #2
Hey rl,
They should rotate in the direction of travel. Your ground is too hard. Wait until a couple days after a nice soaking rain. The 201 is a good machine, but is more of a cultivator than a ground breaking machine. You need to get into the 700 800 or 900 series for a true groundbreaker.
   / bcs 201 tiller tines running backwards #3
If it is anything like my Troybilt, to break hard ground, you have to keep going over and over it, digging a little more each time using the depth adjuster...
Once you have it broken up, typically two passes and the tiller will go as deep as it is going to go...
Well thanks at least I know it is working correctly.
John Deere 24ft Harrow Drag (A47484)
John Deere 24ft...
2025 AllMetal K0307 UNUSED 7 ft. Corrugated Metal (A47484)
2025 AllMetal...
2019 FORD E-350 CUTAWAY BOX TRUCK (A43005)
2019 FORD E-350...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A43005)
2018 INTERNATIONAL...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A44572)
2018 Toro...
2021 FREIGHTLINER SD122 SLEEPER (A43005)
2021 FREIGHTLINER...
