BCS 715 Spline specs?
   / BCS 715 Spline specs? #1
Trevj
Interior British Columbia
BCS, FE-35, Mitsubishi 2500, Gravely 524 project
Hey all,
I have a older 715 with a 8Hp electric only start Kohler on it.
Kicking around the idea of using it with a few other projects, as a hydraulic power source.
Are the splines a proprietary format, or a I like to find matching sections of spline shaft, or spline bushings available anywhere, that would be cheaper than hacking a PTO extension?
Currently, I have a tiller and a 30" sickle bar for it. The sickle bar is a little light, and I am in the process of getting an extension for it to get the balance back where it need be.
Been doing some plotting as to a wagon to pull around with it, possibly with a hydraulic dump bed, among others.
Anyhooo.... Anyone got a line on a decent source for spline parts?
Would I be better off to go straight to the new style fitment, with an adapter, and go from that to adapt to the PTO source?
Thanks!
Trev
   / BCS 715 Spline specs? #2
Hi! I have a Grillo 107d The pto spline shaft is as 715-735 BCS. Spine shaft is DIN 5482 18x15 18 mm x 15 mm. Hard to find in America but easy in Europa. Personal I use Grillo fast hitch adapter. They have a spline shaft and a spline bushing. About $70. I adapt hydropump for logsplitter and Toro front end snowblower . Good Luck Oldmech
Thanks Oldmech, that is just what I was after.
A Google search of the DIN spec and the size together, finds quite a few suppliers of sundry pats that may be adaptable.
Trev
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
Master MGH6500IE 6500 Watt Portable Generator (A50325)
Master MGH6500IE...
Year: 2008 Make: Chevrolet Model: Suburban Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 219,... (A51694)
Year: 2008 Make...
KSI Conveyor (A52748)
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
