Be careful of dealer installed block heaters
   / Be careful of dealer installed block heaters #21
We use our tractor at those temps.
Note please, that I didn't say "use", I said "store". If you park your tractor out in the mud and the blood and the beer - and don't use a block heater - then of course go to a 60/40 mix. Remember also, John Deere says not to go stronger than 60/40, so you should check with MF to be sure.
But if you park you tractor in protected conditions, stick with the 50/50. Warm the engine up after starting so that the thermostat opens and you've got working temperature coolant circulating. At that point, an outdoor temp of -34F becomes academic. I'm also gonna wager that you've got some kind engine heater. When used correctly, they also make anything stronger than 50/50 just a waste of money.
//greg//
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
John Deere 333E (A47477)
John Deere 333E...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
