Belt on 42" snowthrower.....extremely tight!
   / Belt on 42" snowthrower.....extremely tight! #1
Mojoman
Bronze Member
Belt on 42\" snowthrower.....extremely tight!
Hi guys,
well, it's the official sign of winter, I swapped out my mower deck for my snowthrower. But, in following the install instructions to the letter (newbie.... /forums/images/graemlins/tongue.gif), the last thing they have you do is install the belt from the pto to the drive pulley for the thrower. I already had the thrower secured into place, and when I went to put on the belt, I had to turn the thrower drive pulley to get it on it was so tight. should it be that tight or should i have set it on the pullet before I slid the thrower into it's final position with the mounting channels flush with the receptacles? This is probably the method I will use to take it off next time as well as when I mount it again next year...but just wondered if the belt being so tight is going to cause an issue, or will it stretch and work itself out as I use it?
   / Belt on 42" snowthrower.....extremely tight! #2
Re: Belt on 42\" snowthrower.....extremely tight!
Mojo- I'm thinking if you were able to get the belt on by rolling the pulley (by hand), it's perfect!
G/luck
Joel
yep, that's what I did, it worried me only because #1) I didn't want to scar the belt by doing that and #2) I've always thought belts that are too tight are a bad thing
I won't worry about it now though, but the dealer had the idler arm pulley spring attached to the wrong side (they have it attached to the left side), so I have to switch that over to the right hand side and I'm ready for the snow! (well except for tire chains) /forums/images/graemlins/grin.gif
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
John Deere 693 Corn Head (A50514)
John Deere 693...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2013 Hyundai Sonata (A50324)
2013 Hyundai...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
