dav-lyn farm
If you know anything about Vermeer round balers, you are probably aware of the clever hydraulic system that they use to maintain belt tension as bales are forming in the machine. I am helping a friend repair this system on his baler. I have found (I think) the problem that is allowing the system to lose pressure very rapidly. There is a faulty check valve on one of the tension cylinders. I am going to replace both check valves, but I have some questions.
How much oil is this system supposed to contain? Is it supposed to be completely full? I am concerned that it would lock up if completely full.
How do you fill and measure the amount of oil put into the system? There are no fill ports in the system, and there does not seem to be a way to see how much oil is in it.
Is it necessary to bleed air from the system and how is that done?
Any help you could provide would be greatly appreciated.
Thanks,
Dave
Thanks,
Dave
