Bench Grinder
   / Bench Grinder #1
johnnydel29
Bronze Member
East of Albany, NY
JD 2305
I am tryinmg to decide betweeen a 6" or 8" bench grinder. I will be using it to mostly to sharpen blades and grinding metal (bevel edges etc.).
Is an 8" better??
Thanks.
   / Bench Grinder #2
Either one will work. It's about like a tractor, a smaller one will do just as good a job all be it a bit slower. I don't know about sharpening, but for beveling steel and things of the like I prefer a machine of this type.
If you can afford it I would go for the 8" and make sure you get one with a good quality motor with a nice power rating.
   / Bench Grinder #3
I'd go at least 8". The larger wheel presents a flatter surface for grinding.
That doesn't matter for sharpening, but is noticable when doing other types of work.
Vic
   / Bench Grinder #5
I have several grinders and generally prefer the 8 inch over the 6 inch. As was mentioned it cuts flatter and is quicker. In some applications flatter isn't better as hollow ground can make a nice sharp edge however you can put a 6 inch wheel on an 8 inch machcine but not the other way around. I suggest getting more than one grindrer though. It's nice to have at least 4 different grades of wheels available without having to change them around. I counted mine and have 5 grinders 4 sanding belt/plate machines that are used to sharpen stuff.
   / Bench Grinder #6
I've got a 6" with a brush on one side that my grandfather built from a 1920's(?) washing machine motor back in the '50's. All I use it for is blades and bevels (and probably less than 10 times a year). Larger would just take up more space.
   / Bench Grinder #7
The bigger you go, the more surface area that you will have on the stone and the more power you should have for removing material. For sharpening, you really want a fine stone and again, the more surface area that you have, the easier it will be to sharpen drill bits, or whatever you are sharpening.
One thing that I think seperates the junk from the decent grinders is the rest. The junk grinders tend to have thin rests that have large gaps between them and the grinding wheel. I like to have a rest that goes right up close to the wheel.
1hp is about right for most things. Less power will disapoint you.
Take a look at the Wilton. Ebay has them listed for $120.
For more money, you can get a much better grinder, but for this amount, you can get a good one that should do anything you need it to.
Eddie
Almac Fuel Tank Body (A51692)
Almac Fuel Tank...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
7021 (A50322)
7021 (A50322)
B&W Companion Sliding 5th Wheel Hitch (A53117)
B&W Companion...
