Grading bent/broken rear blade
   / bent/broken rear blade #1
Anonymous Poster
Epic Contributor
High Folks,
My first post, I am a new Mahindra 4110 owner (21hrs now)
In my first 5 hrs using a brand new Woods RB72 rear blade I broke check chain, bent blade, and cracked blade edge piece. I had taken off my Bradco 509 hoe before hand and check chains were wearing against hoe subframe. Check chains should have been shortened I believe. I am new to tractoring and don't know much of what I am doing. New tractor way too excited! But in addition to a FEL the only implements I have are the hoe and blade. Since my Dealer who I like, knew this, I thought the check chains wouod have been dialed in for the blade considering the hoe subfframe intrusion into the 3-pt work area. I was pushing not pulling when blade bent. Should I have something solid like a pittman instead of chains if i am going t be doing alot of pushing? Any other help or hints to a new tractor driver would be appreciated.
   / bent/broken rear blade #2
I usually tighten my check chains up so I don't get any sway. I have a 7' back blade and it would be easy to ruin it. I have noticed it I catch the corner with anything it tends to flex. I really have to watch it. I have it hooked to a 50hp jd.
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
