bent lift rod
   / bent lift rod #1
jsanders420
MF 1533
My right lift rod is bent a little below the adjustment collar and threads. The hitch is , anted a little to the left but not too bad. I use the quick hitch. It's a MF 1533. Trying to save a trip to town and get started plowing before it starts raining again.
Thanks guys
John
   / bent lift rod #2
Sorry to hear you bent a lift arm, but not really sure what your asking ?
   / bent lift rod
I don't know why I did. I was wondering if I had to fix it or could I use it. then I thought if someone asked me that I'd say " go try and see". I can use it. I just plowed with it. So it's no biggy. Thanks though.
   / bent lift rod #4
Thanks guys
John
the original owner bent the right lift rod (the adjustable one) near the connection with the lift arm on our TD95D and I put it on the shop press and straightened it out. It's probably a lot bigger lift rod than yours.
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
