Bent PTO shaft
   / Bent PTO shaft #1
cubstuff
Is there anyway to straighten or otherwise repair a PTO shaft that has been bent while in use? Seems as if part of the quick hitch on the tractor was hitting the PTO shaft while it was spinning. Thanks.
   / Bent PTO shaft #2
It would most likely cost more to have the shaft straightened(if possible) than to just replace the shaft. Most farm supply places sell replacement shafts(Farm&Fleet, TSC, etc.). You press out the shaft from the yoke, press in the new one, then cut to length.
   / Bent PTO shaft #3
Instead of taking it to a Farm Supply/ Tractor dealer. You could take it to an business that works Automotive Powertrain, (aka drive shafts).
I had one done on a 6' cutter and it cost around $75 for a new shaft and new universal joint. The shaft was almost twisted into due to hitting stumps and other things besides grass.
   / Bent PTO shaft #4
My local farm supply store has them for around $10 and yokes for about the same as well.
2013 Ford F-250 Animal Control Truck (A50323)
2013 Ford F-250...
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2010 Kubota L3400 (A50120)
2010 Kubota L3400...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
