Ber-Vac S-60 snowblower
   / Ber-Vac S-60 snowblower #1
Builderboy66
Satoh Bison
I recently bought a Sato bison tractor with a front mount snowblower. I am new to PTO driven equipment and was wondering what speed to run the PTO at. It offers 540 and 1092 RPM. Also has a ber-vac undermount drive underneath the tractor with a gear drive box on the back. Wasn't sure how this comes into play with the whole assembly. Any information someone might have would be a great help. thank you
   / Ber-Vac S-60 snowblower #2
I run the blower on my B7200 on the high speed pto.
   / Ber-Vac S-60 snowblower #3
Call the Ber-Vac people if you are not sure.
Tried that. Apparently they had a fire in 2016 and lost most of their archives.
   / Ber-Vac S-60 snowblower #5
Just a homeowner, not a mechanic, but everything I’ve ever used has been a 540 pto.
I always run pto equipment at the max when in use, which is about 2500 rpm; basically just short of the red line on your tach.
That’s especially true for a snowblower, because it won’t thtow well and the chute will jam easier if you’re running too slow
   / Ber-Vac S-60 snowblower #6
Running off the rear PTO I would also suspect 540. Have you tried operating it to see how the blower works when at 540?
I did but had my RPMs way too low it sounds. I will try around 2500
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2022 KMC 21-39-HD LOT IDENTIFIER 183 (A53084)
2022 KMC 21-39-HD...
International Acid Tanker Truck (A52377)
International Acid...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
JOHN DEERE Q820M LOT IDENTIFIER 229 (A53084)
JOHN DEERE Q820M...
