BEST CHAIN FOR CUTTING RR TIES??
   / BEST CHAIN FOR CUTTING RR TIES?? #1
saltbranch
Suggestions?
thank you
   / BEST CHAIN FOR CUTTING RR TIES?? #2
disposible
   / BEST CHAIN FOR CUTTING RR TIES?? #3
Chainsaw chain.
I find that log chains dont cut very well:laughing:
seriously, dont over think it. I cut ties and electric poles with just whatever saw I happen to grab. Worst think it can do is dull it out and you'll have to re-sharpen.
   / BEST CHAIN FOR CUTTING RR TIES?? #4
I've used whatever is on the saws at the time too. If I had a choice before starting, I would put on semi chisel for ties.
   / BEST CHAIN FOR CUTTING RR TIES?? #5
If the RR tie has dirt and rocks on it or in the cracks, I would be concerned. I would not cut in the spike area or at the ends if the steel S is in the end of the tie. If the tie is solid without cracks you should be good. You might consider a chain or blade that is already worn.
   / BEST CHAIN FOR CUTTING RR TIES?? #6
I would grab the oldest POS chain I had for cutting RR ties.
   / BEST CHAIN FOR CUTTING RR TIES?? #7
Any old chain I had, plus have lots of spare chains on hand.:2cents:
   / BEST CHAIN FOR CUTTING RR TIES?? #8
Use one that you're ready to toss anyway and grind the 'rakers' down a bit extra when you sharpen for the job. Brush a bit of #2 or kero on the bar & chain if they gum-up with creosote when cutting. Embedded gravel/sand will be 'the end' of the chain ...
   / BEST CHAIN FOR CUTTING RR TIES?? #10
Do not get the creosote on your skin. learned that the hard way as a teen whilst taking an old bridge apart.
84'' Bucket (A47384)
2013 Ford Taurus Sedan (A50324)
2013 Ford Taurus...
2011 Ford F150 XL Pick Up (A47384)
2011 Ford F150 XL...
2023 Third Coast Equipment RA12H Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2023 Third Coast...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
