BEST DISC ANGLE TO PLOW W/DISC HARROW
   / BEST DISC ANGLE TO PLOW W/DISC HARROW #1
gafarmer
JD 5203
What's the best angle to use on the harrow when plowing with a 6 1/2 foot disc harrow in wide open fields where I plan on planting wildlife food plots? /forums/images/graemlins/confused.gif
   / BEST DISC ANGLE TO PLOW W/DISC HARROW #2
Pick the angle that works best for the soil and debris conditions you have, and the weight that you may (or may not) have on the disc.
That is what I would do. /forums/images/graemlins/wink.gif
   / BEST DISC ANGLE TO PLOW W/DISC HARROW #3
First, I would set the most aggressive angle with about 300 lbs of additional weight and see how well your tractor handles it....lighten the load and/or re-adjust the angle as needed.
   / BEST DISC ANGLE TO PLOW W/DISC HARROW #4
It depends on what type of soil you are working up. If it is sod I would set it very sharp for the first couple of passes and then move it back after that to work up the soil real fine. You don't want to plant in clods. If it is bare soil I wouldn't set it very aggressive so you leave a nice seed bed. You want to set it so it goes in but doesn't leave the soil in big chunks it may take a couple of passes.
   / BEST DISC ANGLE TO PLOW W/DISC HARROW #5
You won't plow with it. The best you will ever do is use it as a disc. Set it at the maximum angle, and set the front gang to run deeper than the rear for the first few passes. Add some weight if you can.
2015 PJ TRAILER  16 TANDEM AXLE UTILITY TRAILER (A52472)
2015 PJ TRAILER...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
BESTWAY AG VSK50 LOT NUMBER 104 (A53084)
BESTWAY AG VSK50...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
