Best place to buy Massey Ferguson parts?
   / Best place to buy Massey Ferguson parts? #1
jon1996
Bronze Member
Whats a good place to buy a Lift Cylinder rebuild kit and a couple other parts for a MF 275? I have no local dealer
Thanks,
Jon
   / Best place to buy Massey Ferguson parts? #3
Use this link, to go to agcopartsbook. Look in the 4th paragraph on the left side and use the dealer locator. Choose one, and they should be able to set you up with a user name, and password to access the partsbook online, or just use the guest user entry.
AGCO Parts Books
If you have high speed internet, you can be looking at the part you need online, with part number, and be talking with your dealer at the same time, on the phone. Having the description and part number ready ahead of time sure does help.
And with the cost of fuel now, they can ship a lot cheaper than you can drive there...
   / Best place to buy Massey Ferguson parts? #5
or better yet take the cylinder off your tractor, take end off and pull out rod. you should see whole bunch of wipers and seals. Leavee them in place and take the whole thing with you to a good hydraulic shop and have them look at it. they can take a quick measurement and get all the parts needed. If you dont feel comfortable doing that then let them rebuild it.
Well I got it all apart, something is weird because the book shows three Orings on the piston, The on came out of it only has one groove and a teflon ring over a Oring, You would think that the oring agaist the cylinder would seal better than the teflon ring,
Also where the cylinder mounts under the cover, the Oring in the pressure Port was flat so I hope it was bypassing there, I still need to check the check valve for the cyliner before I get parts
Jon
2019 Dodge Charger Sedan (A46684)
2019 Dodge Charger...
2019 Freightliner M2 106 TMA Flatbed Attenuator Truck (A45336)
2019 Freightliner...
2019 Freightliner (A45336)
Amkus Rescue System (A46683)
Amkus Rescue...
2019 EZ-GO Golf Cart (A45336)
2019 EZ-GO Golf...
2010 Hyundai Accent 2 Door Hatchback (A45336)
2010 Hyundai...
