best place to find inexpensive gauge wheels?
   / best place to find inexpensive gauge wheels? #1
gladehound
Veteran Member
PA
Kioti DS4510HS, Exmark Laser Z, Kioti LB1914
Hi all,
My objective: make a rear blade with guage wheels so that I can quickly remove snow from my 4500 square feet of gravel driveway.
Gravel details: I have 1/2 inch clean gravel. Looks nice but does not pack well.
Concerns with other solutions I've read about after doing a search: The other three solutions I've read about are the PVC pipe over the cutting edge, skids, and using the blade backwards. With how loose my driveway is, I think all of these options would move more stone than I want to. I think a nice fat set of wheels is the best way to go.
Thoughts on design: I'd like to have one wheel just behind each end of the blade so that each side could float independently.
What I have aready: A used 6' rear blade in good condition. Looks like a less expensive model. no optional end plates or guage wheels.
What I need: An inexpensive set of wheels that I can rig up to adjust the height from zero space to an inch or two of space. I don't think I'll need that much space but will design it in just in case.
My skills: not much. I can drill holes, grind, cut, and bend things. I also know how a bolt and nut work together ;) I don't have a welder but my cousin has one and I'm sure I could get him to weld up some pieces if I need to.
Anyone have thoughts on where to get the hardware I"ll need without paying much? :confused: (hint - free would be ideal, but almost free would work) Already spent all my extra money on the tractor and the 68 tons of stone I'm using to extend the driveway. :D I feel like my wallet is bleeding.
   / best place to find inexpensive gauge wheels? #2
Ron,
Sorry if this isn't exactly on point. Gauge wheels would be nice, but it won't be terrible w/o them. I've got a couple hundred feet of gravel to keep clean in the winter too. We got hit pretty hard last year, and once the ground freezes the blade doesn't really hurt the driveway.
You've only got to be careful in the spring and first couple snowfalls. Even then you just position the blade up a little bit and go. By about the 2nd or third time you've got to plow, you can just drop the blade with no worries. By then, it should even actually follow the driveway pretty good.
My .02 would be to consider gauge wheels an accessory, not a necessity, and just keep your eyes open till you find a good deal.
Hope that helps.
Joe
   / best place to find inexpensive gauge wheels? #3
Option #1: Get the spindle and wheels from Agri-Supply for about $50 a piece. Product Listing -
Option #2: Get only the spindles from them and get the wheels from Harbor Frieght. You can get both wheels from them for about $20.
Option #3: If you have access to free welding, then your options are unlimitied. You can still buy the wheels at HF and have your cousin do you a favor. Do a search on guage wheels. You should find a lot of good ideas.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2019 JOHN DEERE GATOR XUV855M 54 UTV (A51247)
2019 JOHN DEERE...
BOBCAT T595 LOT IDENTIFIER 140 (A53084)
BOBCAT T595 LOT...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
