Best place to talk zero turn mowers
   / Best place to talk zero turn mowers #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
Can you guys tell me where the best place is to talk and learn about the different Zero Turn mowers? I am looking to buy one to cut my property, (5 acers) and want to make an educated decision?
jim!
   / Best place to talk zero turn mowers #3
This is a fine place for said questions. You may also want to try lawnsite.com which has pros and homeowner forums. From what I have read on these sites, the top mowers are Ferris, Scag, Exmark, Bad Boy, and Hustler. I am sure there are some I've left out. I would try to get dealers to bring the mowers out for test mows on your property. ZTRs require careful handling on hills, and some cut better than others. If you are mowing 5 acres, comfort is important, so the test drive on your terrain may make all the difference. Many say the dealer is as important as the brand of machine, so that's another thing to evluate. Good luck, and post pics of your winning selection. Brian
Thanks fellows for the advice.
Now the learning and searching begins...
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
