Best spray lube for PTO collars and 3p Hitch
   / Best spray lube for PTO collars and 3p Hitch #1
dannydan3
I have tried Liquid Wrench dry lube, and WD-40 attracts dirt.
Anyone know of a top grade spray lube for these? Given what a loose mid PTO did to my HST, I want to make sure that the collar is well seated and happy.
:eek:
   / Best spray lube for PTO collars and 3p Hitch #3
Yup, Fluid Film is the way to go!
   / Best spray lube for PTO collars and 3p Hitch #4
I also use FF but keep in mind as it is lanolin based, it stinks as in smells bad.
   / Best spray lube for PTO collars and 3p Hitch #5
:eek:
for the tractor end, i always repalce the pto cap as soon as any implement comes off.. that usually entails a shot of wd-40 and a wipe with a rag to clean it, then a swipe with grease.. then the pto cover. On the yoke end, I spray the inside out with wd, pusha rag thru to clear it, use the finger to add a lil grease to it, and then slip a 1-gal walmart ziplock bag over it and secure it with a rubber band. Works great.
Old bycycle grips or shory pieces of rubber hose or pvc make great covers for 3pt pins.. add a lil grease slip it on, then remove later and wipe with a rag.. clean is it and leaves a lil lube for the initial connection.
soundguy
   / Best spray lube for PTO collars and 3p Hitch #6
fluid film is the best lube product to come down the line in years! Im actually holding my own with it in the ages old war known as fertilizer vs steele.
   / Best spray lube for PTO collars and 3p Hitch #7
I've found 'paint' works pretty good on fertalizer vs steel.
soundguy
   / Best spray lube for PTO collars and 3p Hitch #8
I use "Chain Wax" That I have for my motorcycle chain. It stays in place, doesnt attract much dust, lube properties are very good. Probably not the best product available for that use. but it works pretty darn well.
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
1041 (A50459)
1041 (A50459)
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
Komatsu PC138 (A50490)
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
