Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
A few days ago when mowing in some really high weeds on a part of my property I've not been on yet, I managed to wrap some 5/8" high tension cable under my rotary cutter. The cable consisted of about 10 1/8" really stiff strands of hardened wire. Apparently a utility company took down overhead wires (copper is expensive) but left the high tension lines. I found a spot where they obviously let that wire drop to the ground.
After laying under the deck for almost 2 hours with a pair of pliers to no avail, I just started yanking and yanking. With my tractor locked in 4X4 in low range and standing on the diff lock, I yanked, backed up 10' or so and yanked again; over and over for almost an hour. I was about 3/4 a mile from my truck and any road. Just when I thought I'd made it, since I was going down a steep hill to my truck, all progress stopped. Being that I'd pretty well had it, I backed up about 50' and put the tractor in M range and took off down the hill as hard as it would run. When I came to the end of my rope (so to speak), out of the corner of my eye I saw the top rip off of a utility pole about 1/3 mile away.
Once I got out to my truck I ran about a full mile out the gravel road, still pulling the cable, and then drove back to my truck. The cable was still coming out of the woods!!
I literally had over a mile of cable attached to my rotary cutter. Being that I didn't want to leave my tractor there, I spent the next 2 1/2 hours bending the cable back and forth over the back edge of my rotary cutter until I broke the cable by hand from just bending it back and forth over and over and over.
Here is where my real question lies. After I got home I thought I'd just take the nut off that holds the stump jumper and blades to the rotary cutter. I took the cotter (sp?) pin out and used my impact wrench to take the nut off. It came off relatively easy; no rust or bad threads. But, under no circumstances could I manage to get that stump jumper off.
I would wiggle and pry over and over, but I never got it off. My 18" bolt cutters would not cut the cable either. So, I used my plasma cutter to cut it off as close as I could to the stump jumper. From there I un-twisted each strand and (2 or 3 hours later) finally got all the cable out from under the deck.
I went ahead and put the nut back on the bolt under the stump jumper and, believe it or not, all seems to work fine now. However, if this ever happens again, how do you get the stump jumper and blades off these things?? Do you have to keep spraying it with WD40 and pry away, or do you have to heat it up to get it off? Or, am I completely missing something?
P.S. Anybody want a mile or so of some really tough steel cable? It's free for the taking!!
