BH 90 Subframe and Hydraulic Side Link?
   / BH 90 Subframe and Hydraulic Side Link? #1
GV40U
Bronze Member
W. OR (Willamette Valley)
Kubota L3430
Does anyone with a BH90 backhoe mount (backhoe removed) on an L3130 or L3430 use a hydraulic side link? Is there sufficient clearance for the cylinder, lift arm and sway control linkage to work around the backhoe sub-frame? I'm wondering if I can add the "tilt" to my "top and ...." I see that Carter and Carter now offers a side link.
Thanks for the help!
   / BH 90 Subframe and Hydraulic Side Link? #2
The tilt cylinder has sufficient clearance on the 5030 with the BH90 frame. Don't know if this helps or not but hopefully a 3130 or a 3430 owner will chime in.
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
JCT Q.A 5' Sweeper (A50121)
JCT Q.A 5' Sweeper...
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
