BH77 - has anyone considered converting mechanical thumb to hydraulic?
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #1
bandit67
Veteran Member
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
Title says it all.
I realize it may be an involved & expensive modification, but has anyone seriously considered doing this?
I can probably think of more cons to actually pulling it off, but not being a hydraulics expert, I know it's possible, but is it even worth further consideration?
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #2
Title says it all.
I think yes. In fact, I posted the same question a while back (albeit for a BH76) but didn't get any response. I would like to convert my thumb to hydraulic simply because of the way I use it which is mostly (these days) picking up and bucking trees. It is a matter of convenience and want, I've found ways to work around a fixed position thumb.
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #3
That would be really cool. I would love to do that to mine. I see they have a hydraulic thumb on some of the new Kubotas. Trying to remember what model it was.
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #4
If I am correct (and I think I am) my dealer offered me a mechanical thumb or hydraulic thumb on my bh77 when I bought it in 2011. I didnt get either one (had already went over budget) but later after my purchase became interested and did research to find that it is offered and is pretty beneficial to those who would use it alot. Wish I had just a mechanical one myself! :confused3:
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #5
Knowing the kind of damage that can happen to hyd thumbs, I elected to spare myself the trouble to modify my mechanical one.....If I was relying on using it for work (which I don't) then a hyd thumb conversion would be on my christmas list
That said, I love the mechanical thumb....:thumbsup:
The smallest hoe that a hydraulic option is offered on from Kubota is the B26 commercial TLB, though it is close in size to the BH77. The BH77 is ONLY offered with a mechanical option. However, I'm sure there are a few dealers out there that move enough of these units that will do an in-house hydraulic modification for their customers.
I certainly am happy to have a good quality thumb on my hoe, after not having one on the BH75 ( I got rid of a Brotec thumb that I hated), but I have used hydraulic thumbs on mini-ex's, and they are incredibly handy, which is why I wouldn't mind doing a conversion at some point. The nice thing about the hydraulic thumb is you can use it at any time without having to get off the machine to set the thumb in place and then retract it by hand, especially if you're wanting to just move one thing in the middle of a task.
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #7
bandit....you are correct. I have seen them on a BH92, and I'm pretty sure that my dealer said that the bh92 hydraulic thumb could be made to fit the bh77. wish I had one....I am trying to convence Santa that I have been good enough this year to warrant getting one under my tree!:laughing:
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #8
Yes. I used a rented Kubota excavator with a hydraulic thumb for a weekend. Man can you get a lot done with a machine like that. I do not understand why they do not offer it on just about everysize tractor that is a little larger. I mean if you can get it on a B26, which I looked at the other week as well, why not one a larger tractor? Oh, the B26 was about $38,000. :eek: I saw one sell on e-bay a while back that went for something like $17,000. Company had used it for one job they had and put 1500 hours one it. It looked like it was in beautiful condition.
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #9
Mounting a cylinder to the thumb is not a major problem, just need to identify overall retracted and extended length and go from there. The BIG hurdle is a valve to function it with. If there is no auxiliary lines or auxiliary valve on the Backhoe, it would need to be added. This would be comprable to adding 3rd function to an FEL. The valve would need a circuit relief in it for the base end of the cylinder, probably about 1/2 the Backhoe pressure relief, so if the bucket was forced against it too far the cylinder rod can push back/retract to keep from bending the rod.
   / BH77 - has anyone considered converting mechanical thumb to hydraulic? #10
I have every intention of modifying mine to hydraulic. While the mechanical one is certainly better than none, I find myself either getting on and off too much to adjust or having to bat things around with the bucket to get it just right to pick up.
I got a 2 x 8" ram that will fit perfect once I cut off the cyl base end and re-weld it 90 deg so the ports will stick out the side. No aux lines to power it so I'll likely just run lines to one of my spare remotes. I can't find anywhere on the boom that I like to mount a diverter valve. I figure having to reach by my left hip to activate is still WAY better than having to get off to move the pins. It will mean an extra pair of lines to connect but a diverter valve would need wires so to me that balances out.
2016 Toyota Camry Sedan (A46684)
2016 Toyota Camry...
KC 28in.x90in. Metal V Bottom Feed Bunk (A49339)
KC 28in.x90in...
3146 (A49339)
3146 (A49339)
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A45678)
2025 REDEDLIFT...
2018 Chevrolet Equinox 1LT AWD SUV (A46684)
2018 Chevrolet...
45in.x15in.x20ft.Feed Bunk (A49339)
45in.x15in.x20ft.Fe...
