Bleeding and old IH D361
   / Bleeding and old IH D361 #1
BrotherDave
craig
IH D361
I have an old IH D361 in my fishing boat. I'm out of town and someone has been doing some work for me, during which we think some air was introduced into the fuel system. The guy doing the work isn't sure how to bleed the system and I'm not either. He plans to start by ensuring the fuel filters are full (two tanks, two filters) and then maybe start at the pump and work through the injectors. Pump first? Do the injectors need to be bled in order of timing? When bleeding the injectors is it obvious which nut to crack open?
thanks for any info
Dave
   / Bleeding and old IH D361 #2
You crack the nut on the high pressure line coming to the injector at the injector , probably get by with cracking about three ,which ever are easiest to get a wrench on to loosen without a fight if you loosen more than 3 it probably won't start and run for you. .In 50+ years I have only loosened injector lines on an IHC engine once .
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
