bleeding perkins 100 series
   / bleeding perkins 100 series #1
kmd
toro
I have a terramite T7 with a perkins diesel in it, I think it is a 1995. I posted on the forum because I figured some of the MF might have the same engine. One day it just would not start and it seemed to be a fuel issue. I can use the lift pump to bleed it up to the injector pump inlet. I pulled off the exit lines leaving the injector pump and during cranking fuel barely spits out. Is there another screw somewhere on the injector pump I need to bleed? Or could it be my fuel pump or injector pump? whats the best way to diagnose these 2? I checked/changed the injector pump solenoid, I even used a new fuel line from a 5 gallon can thinking my fuel tank/line could be clogged.
   / bleeding perkins 100 series #2
I had an old Perkins diesel back in the 80s that needed to be bled because it had air in the system and it would not run. I pulled 1 of the metal injector lines lose and off and cranked the diesel. I put it back on and it ran fine. This was in a sailboat many years ago.
   / bleeding perkins 100 series #3
On most of the CAV pumps, there a double headed screw by the name plate on the side of the pump..
U loosen the 5/16 part of the screw, if the engine has a supply pump,?? crank the engine till u get fuel squirting a 1/2 mile, then tighten..{joke}
NEXT, loosen ALL THE LINES AT THE INJECTORS.. & crank the engine till fuel squirts out & tighten..
IF u have fuel UP TO the pump inlet & nothing out at the injector lines.. u have a problem w/ the injection pump.
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
19009 (A48082)
19009 (A48082)
2022 CATERPILLAR 299D3 XPS SKID STEER (A51242)
2022 CATERPILLAR...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
