Block Heater Gone Bad?
   / Block Heater Gone Bad? #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
I have a block heater installed on my B2410 and believe that it has shorted out. Cannot plug it in as it blows a circuit breaker. When the rubber electrical plug is removed, there is evidence of water on the inside of the heater connection and black marks on the rubber plug due to a spark. Has anyone ever had a block heater go bad, short out or leak at the center of the plug. Plug does not appear to leak at the screw-in connection to the block. I guess I'm going to replace this plug. Interested in knowing if this is a common problem.
   / Block Heater Gone Bad? #2
Probably not that common. Usually the problem lies with the cord where it plugs into the heater.
Egon
   / Block Heater Gone Bad? #3
It's been my experience that it's the cord that's bad. You can take a continuity tester and check across the prongs on the block heater to test it if in doubt.
Used an Ohlm meter to check the block heater and there was zero resistance on the two pins. The electrical cord checks out ok without a short. Block heater must have shorted out.
   / Block Heater Gone Bad? #5
Next on Oprah - When good block heaters go bad - we talk to the frustrated owners... /forums/images/graemlins/tongue.gif
Bummer that it shorted out on you. At least they aren't too expensive.
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2013 PETERBILT 367 (A53843)
2013 PETERBILT 367...
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
