Block Heater Issue
   / Block Heater Issue #1
Becharpa
Bridgton, maine
Mahindra 2015HST
I accidentally had a piece of my screw driver fall into block heater hole while I was taking out the freeze plug? Any thoughts? Can I flush it out? Tried magnet can't find it? Will this harm my engine? Your help is appreciated.
   / Block Heater Issue #2
Would not believe any harm can happen as it is in the water jacket area and only water/coolant flows there, mind you if it were to block a very tight water passage area then a 'hot spot' could occur.
Personally I would not worry.
The only thing your magnet will find is the engine block and ignore the bit.
I
   / Block Heater Issue #3
I had the freeze plug fall in mine,,several hundred hours ago,couldn't get out and no problems.
   / Block Heater Issue #4
A long shot but it might be worth while to take a look with a small inspection mirror/flashlight and or try a set of mechanical fingers.
I wouldn't think the velocity of the coolant in the lower block will be high enough to lift it up anywhere disastrous.
   / Block Heater Issue #5
The radiator will act as a fliter to stop it from circulating!! :laughing:
Don't worry about it,,,, :confused2:
Kubota RTV500 (A47384)
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
2001 JOHN DEERE 8410T TRACTOR (A51243)
2001 JOHN DEERE...
John Deere 893 Corn Head (A50514)
John Deere 893...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
