BM40 4 Spool Valve Plumbing
   / BM40 4 Spool Valve Plumbing #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Hi everyone, I知 in the process of plumbing my 4 Spool BM40 Valve. I知 running 3/8 lines to my implements. I will be supplying the hydraulic fluid from the power beyond on my 2004 JD4210. My question is, will a 3/8 line from the power beyond supply enough fluid? Also, with 3/8 line, will I have enough return flow back to the tractor? I think the tractor has 7gpm & max 2125psi. Thank You
   / BM40 4 Spool Valve Plumbing #2
3/8 will work just fine for the work ports of the valve. But you might want to run 1/2 for the Pressure, PB and Tank lines just to be safe.
   / BM40 4 Spool Valve Plumbing #4
I ran 1/2 lines for mine for what it's worth.
E.
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
JOHN DEERE 7210R LOT NUMBER 262 (A53084)
JOHN DEERE 7210R...
Ford Stakebody Truck (A52377)
Ford Stakebody...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
