Bobcat 331 Temperature sender
   / Bobcat 331 Temperature sender #1
cgarai
Healdsburg, ca
JCB Sitemaster, Bobcat 331D Excavator, Austin Western Super 300 Grader
I have a 331 s/n 232511798 with a Kubota V2203-E engine. The temperature gauge rapidly rises from cold to hot and then the motor shuts down. I know this is not an actual overheating problem because this will happen with the engine cold and barely warm by the time it shuts down. Does anyone know where I can find the temperature curve for the sending unit so I can see if it's behaving as it should?
Another issue is that the hydraulic fluid temp light is on. Again, the fluid is almost cold.
I'm having issues with the panel so I sent it off to ISOCELL to get it repaired. I've read somewhere that these issues can be a panel malfunction.
Thanks,
Chris
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Yanmar YT359 (A53317)
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
