Bobcat 341 Excavator has no power under load
   / Bobcat 341 Excavator has no power under load #1
Dirk Lately
Bronze Member
near Portland, Oregon
Kubota L3000DT, Bobcat 341, Taylor 414ce
My beloved Bobcat 341 with 2400hrs started misbehaving yesterday. First it ran fine for probably 90 minutes, then, When applying load on ANY function, the engine began to bog down to the point it would die if I didn't relax the control. Everything still moves, but only very slowly, otherwise the engine will bog and die.
I'm not a mechanic and at this point just trying to troubleshoot. I'd really appreciate any help, especially steps to isolate the issue.
   / Bobcat 341 Excavator has no power under load #2
The 341 has a variable displacement load sense pump. When working correctly the pump senses flow at pressure and adjusts flow rate to match engine horsepower to prevent bogging as described. Testing/adjusting the pump is very detailed process that requires special hydraulic fittings, gauges, and adjustable load flow meter.
First step is identify or rule out a problem with the engine. Check air filter and intake system to make sure no air flow obstruction. Check fuel supply; clean uncontaminated fuel, clean filter, and working lift pump. Run engine to full throttle and move one of the hydraulic functions while watching the exhaust smoke.
1. Trace of black or gray smoke is normal at engine start
2. Engine warm at full RPM should see no smoke. If there is trace of black/gray smoke indicates engine problem; air supply, fuel supply, poor injection.
3. With hydraulic under load should see black/gray smoke as engine attempts to recover RPM. If no smoke at this point I would suspect injection pump governor not responding if all else has been eliminated.
If engine problem is ruled out then best bet is contact dealer. Either the torque limiter is stuck or is obstruction in load sense line.
This is super helpful to me, thanks SSdoxie!
1-Pallet Misc. Items (A50860)
1-Pallet Misc...
2003 21ft Center Console Fishing Boat with T/A Boat Trailer (A48082)
2003 21ft Center...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 International DuraStar 4300 26ft. Box Truck (A48081)
2015 International...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2011 BMW 128i Convertible (A48082)
2011 BMW 128i...
