catdozer
Platinum Member
- Joined
- Sep 18, 2011
- Messages
- 513
- Tractor
- john deere
Need help with the code. Its a 2006 t190. It will work just fine then throw a code. Where do i start? Ssdoxie?
32-49 is Lift Actuator Short to Ground:
Is code 32-65 also present? If not try steps listed in order.
1. At the control valve swap the actuator harness connectors (connect lift to the tilt harness plug & tilt to the lift). If code changes to 32-50 the Lift actuator is shorted internally - replace it.
If code does not change
2. With harness unplugged at actuator, check for continuity on wires #4670, 4680, & 4690 to ground. If continuity to ground is present on any of these replace harness.
3. Check continuity on wire #4670 at actuator plug to controller plug. If open circuit replace harness. If continuity is present, wiggle/twist the harness to see if connection opens - looking for a partially broken wire at this point.
Note: Also inspect pin connections in the plugs looking for a loose or corroded connection. No signal to the controller in 4670 wire will trigger this code, same as short to ground.
If you do need to replace actuator check the software version in the machine if it has not been updated in past 1 1/2 years. New actuators require 54.6 (believe that is correct version #) or newer. There is a tag on the actuator stating version need. With key on press & hold the Bucket Position button until a number shows in the display.
Thank you. Nope just 32-49 is showing. After awhile it stopped throwing code and worked just fine for the rest of the day which was about 4 hours, im about 80 miles from the machine so it will be monday till i get back. If it turns out to be an actuator, how much and how hard are they to replace? Should i do both?
Undo the 2 Allen-head bolts then pull back on actuator to expose push pin that goes through actuator tube and eye in end of the spool. When putting actuator on tighten the 2 bolts evenly and DO NOT torque tight, just snug it up. Best if you get new bolts for this, they will come with Loctite pre-applied so no chance of dripping thread lock into actuator or valve. Lift spool is the bottom one of the 2, first spool in the series, closest to inlet flow. Caution: the new Actuator requires a minimum software version in your machine controller, it will have a tag on it stating the software number. With key on; push and hold in the Bucket Positioning Button, hour meter window will display the software version loaded in you machine. If you number is higher than the tag on actuator your OK, but do need to go through the calibration process. I always recommend having the dealer to the install because he can update if necessary plus calibrate with the service computer will also check the valve for any abnormal resistance in the spool, or voltage drop in the wiring.
