Boer Goats
   / Boer Goats #1
hotiron01
Wharton Tx
JD 3038E
I plan on getting in to the Boer goat business in the near future. I am looking for ideas as far as facilities and doing them as cheaply as possible. We plan on starting with 10 does and working our way up from there. My son is currently raising 2 goats for the show at our county fair, and has convinced me that this is the way we need to go. Looking forward to any comments or advice that ya'll have....
Thanks,
David
   / Boer Goats #2
We are also relatively new into goats. We started with 2 boers (wethers) for the kids for 4-H last year, then this past summer we bought 2 more wethers, a boer doe, and an Alpine doe. Obviously the wethers have all been sold at the fair, but we still have the 2 does. They are the craziest things, never did I imagine the type of personality they have. We are getting ready to get some more. 2 more wethers and another Alpine doe and another boer doe to "back-up" the wethers. Then this fall/early winter the first 2 does will be bread. Hoping to have the boer to produce around February and the Alphine to deliver around the end of May first of June right before the fair.
Anyway, since we have such a small heard we started out with 10x10 dog kennels. I think we have 14 of the panels. We have them all linked together. For shelters for the summers I started out with 2 4x4x4 little boxes that I had made and covered with tin from one of those metal car ports that had hail damage. Then since that wouldn't be good enough for winter shelter this fall we took our 8x16 shed and turned it into a barn. We've moved their food, hay, baking soda, and minerals in there. Then we keep the bottom of it covered in straw. I have a small loft in the back of it to keep their hay & straw up on. Since the shed had double doors on it, we've left the one closed and tied the other one back. Since it is now pretty cold here (you won't have to worry about that) I took a sheet of OSB and covered half of the open door. I also ordered some of that heavy thick plastic like you see once in awhile over a freezer at the grocery or on a big loading door. I'm going to let it hang down from the OSB while it is cold. If it looks like it will start droppiing below 10 degrees or so, I will probably add a heat lamp or two. I want to minimize that though. Don't want them too warm and not be able to take the cold and also want to make sure it is up out of the way so they can't get it and either chew on the cord or start a fire with the light and the straw. Since they are for show, I just want to make sure their ears don't get frost bit - besides that is cruel to make them suffer that way if I can prevent it. We try every day or so to clean any major wet or poop spots up, but inevitibly you miss some, but every couple weeks we will remove all (or most) of the straw, sprinkle some baking soda around the floor to absorb the oder, and then put down all new straw. So far it has worked well, but at some point would like to have a larger (and real) barn with a dirt floor and a larger pasture area, but for now we are making do.
Keep us posted and good luck.
   / Boer Goats #3
Our two boers (Sid & Nancy) are rescues and completely spoiled pets, but the basics are the same no matter what and jwstewar hit all the high spots in the post above.
Since ours weren't planned as soon as they arrived I hit the 'net and did a crash course in goatkeeping. Still learning every day but these two sites are my go-to for anything I need to know. The first is busier and a little more pet-oriented although there are plenty of commerical goats folks who contribute. The second seems to be just the opposite, but both are a treasure trove of goatie info.
The Goat Spot - Goat Forum
goatwisdom
   / Boer Goats #4
We started out a few years ago, with a few head of good registered Boer stock. Found and purchased a buck with excellent bloodlines. Things mushroomed from there, and at one point we had a tolal of 150! Most people think you raise goats by buying them and letting them go. Don't believe it!!! Boer goats have had most of the natural diusease resistance bred out of them. They require worming and hoof trimming once a month, and if you get into this, you'll become the mosts educated goat vet in the area if you do it right. You will find this the most time consuming, costly and most labor intensive enterprise you've ever tried. With the cost of feed and hay right now, everybody in this area has sgiven up on he goat business. Take an old fools advice and DON'T DO IT!!!!
   / Boer Goats #5
Hotiron Have 4 pure boers 2 does and 2 bucks, 2 boer crosses both does and 3 dairies all does. I was looking at getting into a larger production but figure I'm gonna stay small. Went to a WSU winter school for meat goats, and to make a living at it the instructor who was in the business estimated you would need 300 animals. Two many for me. I just keep to several for me and the rest I sell off. I am working at making my feed costs back, that way I get free meat for the freezer. I generally have all my goats sold off before they hit the ground, and I do mostly word of mouth. We have been doing this for about three years now. The dairy girls we use for milk and cheese.
JWSTEWAR Leave the hay down on the ground, and as you find the wet spots and poop throw some hay on it to cover it. This will keep the smell down and as it composts it creates heat. I have a three sided shelter and a fully enclosed shelter and the goats prefer the three sided. I have put my compost thermometer into the straw and have had readings as high as 110 F. When it gets to be about a foot thick I clean it out and start again or roughly twice a year. Just make sure the excrement is covered with fresh straw or hay and you be good to go. If you garden it makes great compost after you clean it out and let it set for awhile.
LJH Try goat beat as well, as fiascofarms.com two more good websites. Good luck to all of you as they are interesting animals and a lot of fun
   / Boer Goats
I appreciate the responses! Not trying to turn this in to a career, mostly doing it for the tax exemption on my property. I have a Boer breeder down the road from me, that will be available to help me out if needed. He is the same guy my son got his goats from, and we have developed a really good relationship with he and his wife. In our area, the weather is mild 90% of the year, so they should do fine. I understand the worming and hoof trimming can be time consuming, but with the right facilities, I hope this can be made a little easier. Keep it coming.......:thumbsup:
   / Boer Goats #7
Combustix,
I would, except this was a repurposed garden shed. So it has a wooden floor. I know this isn't the best scenario, but for now it is what it is. They seem to enjoy it so far. Though every now and then the boer doe will decide to sleep outside - including last night. LOL. We do use the used straw to cover the mud that develops by the gate where they stand. We also put it on the garden.
We are amazed how much we have to learn real quick. The boer injured her knees this year. So after taking her to 2 different vets and them going cultures to tell us, yep, it has an infection and saying there is nothing we can do to, don't breed her, to you might have to put her down, my wife did research and we drained them a few times, put a couple different types of salves and wrapping them, we have them back to normal. We've learned to give them shots for vaccination and penicillin for the knees and such. My son also did a woodworking project for 4-H, guess what he made....a goat stand.
   / Boer Goats #8
I live in Brazoria county, Lake Jackson area, if you are looking for good sound advice in your area talk with Dudly Thomas in Danciger,, he knows more about goats than I know about beer,, and I know a lot about beer,, there are two kinds,, cold and real cold.. if you plan on using goats as Ag ex,, two goats per acre,, or one cow per five acres if Wharton county is like Brazoria county it is based on 200 pound pre acre.. Lou
   / Boer Goats #9
That's what we're doing too, it saves work, keeps them warm and IMO you can never have too much compost around a homestead aspiring to permaculture. And thanks for the site suggestions. I've been to fiascofarms and it's great, the other I never heard of but will check out.
Goats are a trip. Ours follow us around like puppies, beg for treats, parkour off everything in sight, make us laugh and trash whatever they're not fenced out of. I read a description recently - much like dogs minus the built-in desire to please - ayup. Goats are have no conscience or sense of guilt whatsoever. :laughing:
   / Boer Goats #10
Good luck with your goat project, Hotiron01.
We have been raising goats for just about 15 years. You are right to do some planning before putting a bunch of animals on your place.
You mentioned "cheap". Trust me, when it comes to raising goats there are two areas where you don't go cheap. They are your fencing and your herd sire.
Here are some Web sites you may find useful:
American Boer Goat Association
Texas Boer Goats - Breeders List
Health
index coni
How to Trim Goat hooves the right way.
Jeffers Livestock
Don't forget to visit our Web site as well.
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52128)
2016 Ottawa Yard...
2018 FABRIQUE 20FT TRAILER (A51222)
2018 FABRIQUE 20FT...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
