Bolens g192 top radiator hose
   / Bolens g192 top radiator hose #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
I am needing some new radiator hoses, I think I can get generic 1.25" ID hoses but where have you had good luck?
I went to an autoparts store and the guy went in the back and found a longer hose with a similar bend. I had to cut off the end and had the right part. To assist getting it off I took off the thermostat housing. It was gobbed with orange silicone. Sure enough, the fitting surfaces were very hacked. I filed them flat with fine file and hooked it back up sans the thermostat. Also installed a new aftermarket temp gauge as the old one had been kaput for a few years. The thermostat gasket had to be replaced with generic gasket material.
Yeah it runs great.
If you have a similar problem bring it up.
   / Bolens g192 top radiator hose #3
just catching thread. sounds like you have it resolved :) and was just about to state take part to local auto part store.
   / Bolens g192 top radiator hose #4
Yeah it runs great.
I believe the OEM hose is 1 3/8" one end and 1 1/4" the other [ID]. Did you have any trouble fitting on the end that was 1 3/8" on the original?
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
1065 (A53342)
1065 (A53342)
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
