Bolt Rating
   / Bolt Rating #1
Jehu Richmond
I am wanting to install a lifting device in the bed of my pickup and want to get the strongest 1/2 inch bolts for mounting the base. How does one determine which bolt to purchase?
   / Bolt Rating #2
I am not sure what kind of load you are talking but just about any 1/2" bolts will work. I am assuming that the mounting plate will have 4 bolts.
grade 5 bolts have a proof tensil strength of 85000psi and grade 8's are 120,000psi.
For 1/2 inch bolts, thats 16,000 lbs per bolt for grade 5 and 24,000 lbs for grade 8. Heck, even grade 2's are good for 10,000 lbs tensil strength per bolt.
So to answer your question, about any bolt will work but since there isn't much cost difference, I'd probabally get the grade 8's. Unless you want to spend a small fortune and get something like an ARP with rolled threads. Like Rod bolts or main cap bolts for a engine. Those are usually around 200,000psi tensil strength.
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
(INOP) CATERPILLAR TH63 TELESCOPIC FORKLIFT (A51243)
(INOP) CATERPILLAR...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
New Harvest T852 8"x52' Transport Auger (A50774)
New Harvest T852...
