BOOM! Then No Go.. Kubota GS1800
   / BOOM! Then No Go.. Kubota GS1800 #1
michauxii
My gargen/lawn tractor was idling and I was over checking a faucet.
Then a clacky "blang" noise.
Seemed to be running a little funny right before the incident.
Now... motor is running good, very smooth, but she won't move.
Hydrastatic transmission.
No signs of any type of oil leakage on the ground or on motor.
We're having a pretty rough storm right now; so the mower is still in the garden.
Just wanted some ideas of what to look for when I can get outside.
Thanks!
Rain eased up so I could take a quick look. Mowing deck will not raise or lower and mower will not will not move forward or backward.
Hydraulic line??
   / BOOM! Then No Go.. Kubota GS1800 #2
I'm guessing your drive belt broke, or one of the pulleys broke
   / BOOM! Then No Go.. Kubota GS1800 #3
The G1800 is a shaft drive from the engine to the HST transmission and hydraulic pump. My guess is that one of your U-joints cratered on either end of the driveshaft. Remove the deck and you should be able to easily see the problem. You can probably see it with a flashlight even without removing the deck.
Thanks for the replies!
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2004 Ford F-550 Mason Dump Truck (A53422)
2004 Ford F-550...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
42013 (A51691)
42013 (A51691)
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
