Boomer 24 routine maintenance
   / Boomer 24 routine maintenance #1
TheMan419
Veteran Member
Indiana
New Holland Boomer 24
Ok silly question..... manual says fuel filter change (among other things) at 300 hours.
Do I need the element for like $15 or the whole assembly which runs $110?
Note that I want to do it right so spring the $110 is fine if I need to. Just don稚 want to if I don稚 have to.
   / Boomer 24 routine maintenance #2
Just the element, and watch for the O-rings when you disassemble. Put a bucket under it and let some fuel flow through to flush the line.
Thanks!
   / Boomer 24 routine maintenance #4
Also ensure you bleed the air out of the system when finished replacing the cartridge...usually a vent plug on top of the filter assy....crack it and get fuel flowing and let it continue till all the bubbles are out.
2010 Wilson Hopper Bottom Trailer (A50514)
2010 Wilson Hopper...
Ford 641 Workmaster (A50514)
Ford 641...
Hours : 1114 (A50323)
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
