Bought a Ford 4000 at auction
   / Bought a Ford 4000 at auction #1
bartman
Adamsville Pa / Williamsport Md
John Deere 2640 / Ford 1710 / MTD 2554 ZERO TURN MOWER
Had a neighbor who bought a Ford 4000 at auction last week
Very clean looking. He drove it home about 12 miles and said it ran good climbed the hill into town in 8th gear did not smoke had plenty of power and was very happy with his purchase Saturday evening. Monday morning was a different story, he had been brush- hogging a little and using a back blade to spread dirt around and they noticed oil coming out of the muffler . It was not burning it ,the oil was just seeping out of the muffler from what I was told
Sound familiar to anyone
Thanks Bartman /forums/images/graemlins/confused.gif
   / Bought a Ford 4000 at auction #2
I don't know that tractor, But I will take a wild shot and bet the oil is extremely dirty. I would find and clean the crankcase vent, (PCV), and change the oil for starters.
   / Bought a Ford 4000 at auction #3
I suggest changing every filter and fluid in that tractor and agree with checking to make sure the crank case breather is not obstructed. At least you will have a good baseline for the maintenance.
   / Bought a Ford 4000 at auction #4
I agree too. sounds like a crankcase vent problem. The pvc valve should be pretty cheap. BTW the Ford 4000 is a great utility tractor. They run forever. I have many neighbors who have been running these literally for decades. They are hard to come by around here. No one who buys one ever sells it.
   / Bought a Ford 4000 at auction #5
Me thinks(which is dangerous) if it's the pcv the oil will go thru the intake into the cyl.where it will burn,mostly,=smoke.Oil dripping from exh.sounds like stuck rings.Might be a good time to try Marvil Misteryoil.OVERLOOK the spelling /forums/images/graemlins/blush.gif
Paul
   / Bought a Ford 4000 at auction #6
sounds sorta like diesel slobber, if it ran nice for that long trip home then i would say he might have an injector problem, or just working it too lightly
   / Bought a Ford 4000 at auction #7
I agree, sounds like slobber aka wet stacking. Go out and put it under a good load for 20 minutes or so and see what it does... if it clears up, it's fine.
   / Bought a Ford 4000 at auction #8
Folks posting info about PCV systems on 30+ year old farm tractor really ought to stick to stuff they know. Taking fuzzy knowledge from automotive applications and extrapolating it to off-road equipment is risky. Put plainly, they don't know what they are talking about because a PCV system doesn't exist on a 4000. Diesel slobber, or really really bad valve guides & seals.
   / Bought a Ford 4000 at auction #9
I think they were just trying to be helpful. My Yanmar 1401 does the same thing. Usually after it warms up for 30min or so it stops smoking. It doesn't even smoke that bad when it does. I'm still contemplating rebuilding the engine or having someone that knows what they are doing do the work. Good luck.
   / Bought a Ford 4000 at auction #10
</font><font color="blue" class="small">( Folks posting info about PCV systems on 30+ year old farm tractor really ought to stick to stuff they know. Taking fuzzy knowledge from automotive applications and extrapolating it to off-road equipment is risky. Put plainly, they don't know what they are talking about because a PCV system doesn't exist on a 4000. Diesel slobber, or really really bad valve guides & seals. )</font> That was a bit brutal. Simply stating the tractor doesn't have a PCV valve and your diagnosis, would demonstrate a bit of knowledge and not your backside. /forums/images/graemlins/tongue.gif I was impressed that folks called 'em PDV instead of PVC which I have had many a customer ask to have changed during a service. It's great that everyone chips in and by finding the common ground, most people get their answers quickly. I would encourage everyone to continue to contribute, as I've learned a lot here and wish to continue...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
