Bounce in Hydraulics in FEL operation
   / Bounce in Hydraulics in FEL operation #1
jkm
SC
Kubota B7510
Has anyone got an idea why the Hydraulics started bouncing in my FEL? I also noticed that sometimes it does this when I am moving. I am wondering if it means I am low on fluid?? /forums/images/graemlins/confused.gif
   / Bounce in Hydraulics in FEL operation #2
I suspect it has to do with the operator handle not being moved smoothly and/or quickly enough at certain RPM's. My B7510 does the same thing occasionally. I just stop for a second and raise or lower the RPM's be a couple of hundred.
It never hurts to check the fluid level every time you use the tractor.
Bill Tolle
I spoke to the dealer and he suggested to check the fluid, but also states that there is a problem sometimes with the ball on the hydro disconnects that sometimes need to be replaced. I am going to check the fluid when I get back to the house.
Thanks Btolle...fellow 7510 owner /forums/images/graemlins/cool.gif
2017 John Deere 652R (A50121)
2017 John Deere...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
