Brake problems (sticking) ON 1991 JOHN Deere 2355
   / Brake problems (sticking) ON 1991 JOHN Deere 2355 #1
buddyc9353
Texas
1991 John Deere 2355
I have a JD 1991 2355 with very low hours, but the brakes stick when it sets up for a bit, has anyone else had this problem with their 90's 55 series tractor? If so, was there a simple fix for it. It seems to be in the master cylinder, I can crack the line on the master cylinder and bleed some of the pressure off of the system and the brake releases but if you use the brakes it sticks again.
   / Brake problems (sticking) ON 1991 JOHN Deere 2355 #2
Not sure about on your tractor but on are 2040 JD greasing the petals pivot point does the trick.
2003 Chevrolet Express 1500 Cargo Van (A46683)
2003 Chevrolet...
2015 Ford Escape SUV (A46684)
2015 Ford Escape...
Case IH 455 Round Baler (A48561)
Case IH 455 Round...
2018 FREIGHTLINER CASCADIA SLEEPER (A45676)
2018 FREIGHTLINER...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A46684)
2015 Ford F-250...
7ft. Rotary Brush Cutter Attachment (A45336)
7ft. Rotary Brush...
