arrabil
Veteran Member
Howdy. I purchased the 4200 a couple summers ago. It was a little beat up and I've gotten it back to near perfect mechanical condition. The only thing I never fully tackled was the brakes.
In 2wd going downhill, it takes a LOT of pedal force to make it stop. Uphill, flat ground, no problem. My driveway is a 17 degree slope and it won't come to what I would call a safe stop. Unless I'm on the pedal REALLY hard the wheels keep turning. The parking brake needs to be pulled really tight to be effective as well.
So I keep it in 4wd all the time. My property is suited to that just fine. In 4wd it will come to a stop on the driveway even without the brakes. And with the brakes its quite a reassuring stop.
I've tried adjusting the pedals to be at the edge of engaging the brakes just as you touch them. This is contrary to the manual saying there should be 3/4" (I think) of slack before engagement. That changed nothing but I can't be sure I did it right looking back on it (it seemed to be a two person job to get it right).
I watched an Amish guy on a 4700 mow down a 30+ degree slope and I would never have the guts to try that the way it is but he did it over and over just fine. The X475 comes to a stop on the same hill just by releasing the go pedal, no brakes necessary.
My tires were not loaded when I got it. There are 1100 hours on it.
Is this normal and I'm just being touchy or should it stop on a dime?
