Price Check Branson 2400 can you put hydraulic oil in front axle
   / Branson 2400 can you put hydraulic oil in front axle #1
Omatchen
Gadsden,Al
2014 Branson 2400
Was told by dealer I could put hydraulic oil in my front axle . I am doing my first 50 hr maint. The manual said use 80-90 w gear oil.I have never owned tractor before . Any advise would be appreciated .
   / Branson 2400 can you put hydraulic oil in front axle #3
My owners manual states to use the same fluid in both hydraulic and front axle or optional 80-90 gear lube in front axle.
Thanks for your input it helps this is my first tractor didn't want to mess up
   / Branson 2400 can you put hydraulic oil in front axle #6
Multi purpose light weight oil with advanced additives has been replacing the old heavy oil for 40 years at least. Only drawback is if you have leaks it will leak more and if you have gear wear your gears may be noisier. Good part is a common oil to stock and in the winter hyd and shifting and steering and all that work better. On one of my Fords my hyd line goes through the bottom of the tranny and has pin holes. As a result I have to periodically drain back down to the fill hole. So, this tractor has been running Ford 134a (multipurpose hyd. tran. fluid) rather than 90 w in the tranny for about 15 years that I know of.
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
INOP/NON-RUNNING Hyster Forklift (A51573)
INOP/NON-RUNNING...
6ft Field King 3 Point Hitch Tiller (A51573)
6ft Field King 3...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
