Branson 2400h oil filter super tight
   / Branson 2400h oil filter super tight #1
Dan Lamb
MC Cloud Ca
Branson 2400h TLB/ cab
Has anyone tired to Get the oil filter off for the first 50 hr oil change ? Branson 2400h There is barley any room to Get any type of wrench on IT .Mine is so tight I broke my oil filter wrench , today I bought 3 different type of oil filter wrenches to try , a strap wrench , a 3 finger wrench and a second type of strap wrench , I sure hope I dont have to try to CUT this off or take IT off in little pieces . Any help or ideas would sure be appreciated , thanks. Dan
   / Branson 2400h oil filter super tight #2
I've never had to do this but I have seen mechanics punch a hole in the filter to release any pressure, they seem to come off pretty easy after that.
   / Branson 2400h oil filter super tight #3
My go-to wrench is the type with 2 half moon pieces of spring loaded metal. They bite in well. For problem filters, a chain wrench works well.
If the filter has the keyed slots near the gasket (like hydraulic and trans filters) tapping or air hammering with a punch works well.
Good luck!
   / Branson 2400h oil filter super tight #4
When I did the first service on my Branson the oil filter was just extremely tight but I got it off with the cap style filter wrench. The hydraulic filter was so tight that I ended up using a chisel and hammer on the base flange to get it started turning after trying strap wrenches, chain wrenches and actually collapsing the sides of the filter, tried punching a hole using a big screw driver and tore a slot in it, I was making a lot of comments that day on the parentage of the individual that put it on. :mur: some days but then it gets better.
Good luck
   / Branson 2400h oil filter super tight #5
I use the three finger style that tightens as you turn on my 2400H. Strap wrench on the hydraulic filters.
   / Branson 2400h oil filter super tight #6
Not just Branson, all the new equipment I buy has the same problem. Get a suitable filter wrench and get after it. I have about 8 to fit different filters and different access points. When I put the new ones on, I abide by the セ turn instructions including wetting the seal. While I'm at it I fill with oil to ensure a good wet start of the engine. Yet to have one leak or fall off....been at it over 60 years.
Thank you gentlemen , I did finally Get that oil filter off after I took a sharpe cold chissel and had to hit IT 12_15 times to Get IT to move then I had to scrape the paint off because the Half moon type wrench Kept sliping , after IT could grab the metal I GOT IT off and the new one on, next weekend the HST and HYD filters , thank you all , Nor Cal Dan
   / Branson 2400h oil filter super tight #8
For a replacement filter I always liked the ones that have a hex welded to bottom ... I believe WIX makes some, but probably not of specific filter you need...
YEs I realize its a K&N, but pic is strictly for example...
Dale
Thanks Dale , I have to use Branson filters because I only have 52 hrs on my 2400 and my dealer said if any thing happens and IT has an after market filter on IT the warrenty will be vold , the guys at Daves Tractor in Red Bluff Ca have been super to work with so I probible should go that rout , thanks Dale
   / Branson 2400h oil filter super tight #10
If you read the Branson forum (on this site) some have had issues with non OEM filters on the hydraulics.
For the little extra I just go with Branson filters.
You can even order from some dealers online.
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
Hustler Raptor Limited Zero Turn Mower (A51573)
Hustler Raptor...
2018 International DuraStar 4300 Dump Truck, VIN # 1HTMMMMNXJH633369 (A51572)
2018 International...
Laymor SM450-ST Sweeper (A51573)
Laymor SM450-ST...
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
