Branson 3550 with loader
   / Branson 3550 with loader #1
heatpmp
Florida: USA
Hinomoto E280
Friend was operating this tractor and struck a tree with the loader moving forward. It has shut the engine down. Motor turns over but won't restart. Appears that fuel flow has shut down. We have flow to the injector pump. It's a diesel about a 1999 model. Does anyone know if there's a safety switch to shut fuel down in the event of a roll over and if there's a reset button?
   / Branson 3550 with loader #2
I would first check the solinoid near the injector pump,check the plug,When you turn the key to "on" you should hear a loud click.If not check for voltage.If not check fuses then check the relays ehind the dash to be shure they are all seated,Im not aware of a saftey shut off like gas cars have
Good Luck
Glenn
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
Land Honor Portable Screener (A50514)
Land Honor...
