Broadcast Spreader Settings for Triazicide Acre+
   / Broadcast Spreader Settings for Triazicide Acre+ #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I know, this is a long shot, but I'm trying to save myself a few hours of experimentation.
I need to spread Spectricide Triazacide Acre+ at the .8LB/1000SqFt rate with my King Cutter 400 Poly 3 point spreader. Has anyone out there done this combination, and what gate setting/PTO speed/Ground Speed did you use. Commence crickets.
   / Broadcast Spreader Settings for Triazicide Acre+ #2
I don't have any hard details to help you, but I had to apply 40 lbs per acre of fertilizer on a pasture a couple weeks ago using a broadcast spreader. It was my first time so I had to make an educated guess.
I knew that a 5 gallon pale was about 40 lbs, I had 6 acres to cover, 6 buckets went in the hopper and I went out. I eyeballed the flow coming out of the hopper and in the end I had a little left over, so I did a couple passes in areas I thought needed a little more.
Worst case, start slow and see how fast the hopper goes down vs amount of ground covered.
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
WARREN POWER SYSTEMS  100KW GENERATOR (A50854)
WARREN POWER...
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
