broke grease nipple G1800 4WS
   / broke grease nipple G1800 4WS #1
Shuttlexman
Greely Ontario Canada south of Ottawa
G1800 AWS Diesel
Hi,
I broke a grease nipple this afternoon - it was loose in the fitting and when I went to pull the grease gun off it broke off leaving the threaded end in.
Is there an easy way to remove the broken end? It's at the front PTO drive bearing.
thanks for the help.
Bob
   / broke grease nipple G1800 4WS #2
Go to an auto supply store and buy an "easyout" that will fit into the hole in the fitting. If it broke off with a little sticking out you can cut a groove across it so you can use a screwdriver to remove it.
   / broke grease nipple G1800 4WS #3
Better yet, at the same parts store in the section they sell grease fitting's get yourself a grease fitting tool. It has a extractor, thread restorer and installer all in one handy little tool.
Success!
Got the broken part out with a $7 extraction tool - thanks for all of the help here.
Now what's the standard grease fitting for this G1800 diesel Kubota? This fitting was on the PTO driveshaft at the front bearing area just behind the belt drives.
Regards,
Bob
   / broke grease nipple G1800 4WS #5
Shuttlexman said:
Success!
Regards,
Bob
It will probably be easiest to take out another similar fitting and match it up at the parts house.
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2008 JOHN DEERE 6330 LOT NUMBER 98 (A53084)
2008 JOHN DEERE...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
