Broken backhoe: repair questions
   / Broken backhoe: repair questions #1
familyman
Platinum Member
Perkiomenville, Pa
Kubota L3800HST
The situation; the bucket cylinder rod snapped on my Bush Hog BH650, and punched a hole in the top of the dipper arm.
After removing the damaged cylinder, I ordered the new rod and a cylinder seal kit, as well as a new lower pin.
Question 1: How hard is it to rebuild a cylinder, and what are the steps?
Question 2: I want to weld a plate over the hole in the dipper arm, to reinforce it. A friend at work said I shouldn't because it's cast iron (?). That doesn't sound right to me, can someone educate me there?
   / Broken backhoe: repair questions #2
The cylinder is not hard to rebuild. Just take it apart and pay attention. Put it back together the same way.
I'll bet ya the dipper arm is just plate steel. The one on my excavator and many I have seen have been welded in the say you propose.
Andy
I didn't think it was cast iron - cast would shatter, this was a deep dent with a hole.
I'm glad to hear that rebuilding the cylinder should be easy. My act of stupidity aside, the backhoe has done alot of work, and done it well.
   / Broken backhoe: repair questions #4
Before you order parts, roll the cylinder tube across a flat or check it with a machinists straight edge. If the rod went thru plate steel, the cylinder may be bent. Just a thought to check.
jb
Thanks, I hadn't thought of that.
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A46683)
2016 Big Tex 14LX...
2003 Ford F-750 Super Duty (A47307)
2003 Ford F-750...
2009 Chevrolet Cobalt Sedan (A46684)
2009 Chevrolet...
Komatsu D51PXi Crawler Tractor Dozer (A44571)
Komatsu D51PXi...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A45336)
2021 Ver-Mac...
vimeo (A2127588)
vimeo (A2127588)
