broken crank
   / broken crank #1
azsnoopdog
mitubishi mte2000
tractor started to become hard to start.motor acts like it had slopp in crank.pulled oilpan found that number 2 piston had a worn bearing and broken crank.is any help for this k3f motor.if not is there a interchangable motor that is avalable?
   / broken crank #2
When you say the crank is "broken", can you give more of an explanation? Is it in two pieces or is it just that the #2 crank journal is in bad shape? Is this by chance a Mitsubishi MTE 2000 tractor? I have been able to get parts for my K3F before; piston, rod, rings but am not sure if a new crank would be available.The K3F engine is considered a Japan only motor but many parts are still available. I would check with Len Sheaffer at
Sheaffer's Town & Country Tractor
320 Palmyra RD
Dixon, IL 61021
Phone: 815-284-3226
Fax: 815-284-5050
sheaftractor@grics.net
   / broken crank #3
I have a k3f engine coming on a container that I am unloading Wednesday.
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
Engel 20' Boat (A50121)
Engel 20' Boat...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
