3-Point Hitch Broken three point hitch
   / Broken three point hitch #1
haystack
long valley, nj
Ford 7600
:confused2:I just got a 284 IH and lifted the draw bar up and know it is stuck and will not lower . Can anyone tell me how to fix this I never had anything like this happen to any of my other tractors.
   / Broken three point hitch #2
I'd assume you mean you lifted the three point. Your tractor should have a knob that turns to adjust the rate at which your three point lowers. If it is turned all the way it will not lower without enough weight on it.
I tried that but it didn't work it almost seems like a metal rod is stopping it . I was told the unit might be off center and I know have to lift the hole seat cover off and I will see the problem
   / Broken three point hitch #4
Does it have a draft control? If so, make sure the draft lever is in the down position.
2013 MACK PINNACLE (A53843)
2013 MACK PINNACLE...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
1065 (A53342)
1065 (A53342)
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
