Rotary Cutter Brush cutter couplings
   / Brush cutter couplings #1
Taylortractornut
Elite Member
Iuka Mississippi USA
3550 Fard Backhoe and a 1948 Farmall Cub,
Does anyone know where i can buy a few female splined couplers for a brush cutter gearbox, the one that go n the stump jumper I have 2 of the same gear boxes one is on a cutter, but its stripped the female splines one the jumper and ilde hate the waste a good cutter. The second one i need the couplers to make something out of the gear box, It seems to be an od sized outer diameter when i mike them, I could make them but i dont have a rotatry head in my power broach. ill measure again tomorrow and count the splines. Any cataloges i could try out.
   / Brush cutter couplings #2
I wore out the spline in the stump jumper of my first rotary cutter (a Howse) and checked my manual for parts. The stump jumper and splined connector are one assembly, but they could be ordered at a fairly decent price as I remember. As it turns out, the light metal structure of the cutter was also damaged, so I just bought a new cutter and never bought the replacement splined adapter. I think if you will contact the manufacturer of your cutter, they can sell you the part. Maybe they will even tell you how to find just the splined adapter without the stump jumper attached. ...it's worth a try.
Id usually just build up one shaft or machine a new one but i had to make a new stump jumper, I have one on a whole cutter i built but i sold it to a fella for mowing a right of way if hed come get it.
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2017 Case CX130D Excavator (RIDE AND DRIVE) (A50774)
2017 Case CX130D...
2010 Ford Expedition XLT 4WD SUV (A50324)
2010 Ford...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
