Brush Hog
   / Brush Hog #1
dtd24
Schenectady, NY
98 JD 1070
I was doing some well needed brush hoging last week, and was wondering if anyone thought of putting wheels on the front side of the hog to help from scalping. When I hog I am constantly looking back adjusting the 3ph to keep level cut as my land is all over the place. Dont the finish mowers have this kind of set up?
   / Brush Hog #2
When brush hogging, ideally the 3ph should be all the way down in float position. The tractor's rear wheels should (sort of) act like wheels for the brush hog. If you keep the brush hog raised up, it doesn't float properly, and you can get all sorts of odd behavior. Also, it's very hard on the 3ph hydraulics.
In my opinion, it's better to scalp once in a while than to keep all the heavy bouncing weight on the 3ph.
Converting the 3ph brush hog to a "pull behind" unit would be the ultimate solution, but be ready to do some heavy-duty fabrication. A brush hog will eat light wheels and brackets for breakfast.
   / Brush Hog #3
I wonder why you say it's hard on the 3ph hydraulics? That is what it is desinged to do. Many implements rely on the 3ph for height adjustment.
   / Brush Hog #4
I think that if you consider what the brush hog was designed to do, chop up heavy duty brush, that wheels would be a detriment to the operation. Like getting tangled in the wheels. I could be wrong, but if it was a desirable trait, I think some manufacturer would have incorporated wheels into the design. Where as a finish mower is not designed to go through any brush.
Just my 2 Cents.
   / Brush Hog #5
I agree... The hog wasn't made to be a finish mower.. it's a rough cut device.
soundguy
   / Brush Hog #6
I was thinking the same thing yesterday while mowing, riding on the skids is to low.
By the time the tractor is over the hump, the mower is into it.
   / Brush Hog #7
After a quick look at your profile, you have without a doubt, enough tractor to handle the mower you own. YOU DON'T "drag" a mower. The tractor (the hitch) can MORE THAN ADAQUATELY carry the front of the mower. The hitch (as well as the rest of the tractor) is designed to carry the weight of implements sized to fit. Unless you're mowing a surface as smooth as a pool table (or a manicured lawn), resting the mower on small wheels on the front corners will probably result in the wheels finding holes and irregularities resulting in MORE problems with maintaining a set position than you already have.
   / Brush Hog #9
A set of limiter chains can help eliminate constant adjustments. Basically you get the mower set at the height you want for the front & then use a set of chains to hold the 3PH at that specific height. You can still raise it for rocks, stumps, etc. but when you lower it, the chains limit the drop to that pre-determined setting. You don't even need to use the position control, just lower the 3PH all the way because the mower is held by the chains.
I had to make a set for my 8N as the position control doesn't really work all that well & I also had leak-down. I made a bracket that attached just below the top link & had a chain down to each lift arm/pin. I made mine with threaded eye bolts on the implement-end so I had a finer adjustment than removing/adding links to each chain. Unfortunately I don't have any photos on hand.
Here is a photo I found online to give you the idea. There are also kits available commercially.
   / Brush Hog #10
If you have position control on your rockshaft lever, you can set how low the 3PH can go.
On a 790, it's quite simple. The rockshaft lever has an adjustable stop which I adjust to keep enough pressure on the lower links. For me, this is because I'll occasionally lose one of the special washers from the Pat's Easy Change system if I lower the lower links as far as they can go....that takes any pressure off the cutters lower link pins.
As long as the upper link is extended, the cutter will bear upon the tail wheel yet the tractor's lower links take part of the load. I know some guys replace the upper link with a chain...and I have just unhooked the upper link on occasion (the cutter floats better on uneven ground). This, in theory, could be dangerous. The cutter could flip up and there would be nothing to slow it's travel.
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
